FS: '87 951 engine and reseal 'kit' [Pickup in Seattle only]
Old 05-21-2017, 09:22 PM
alxdgr8
alxdgr8's Avatar
Default FS: '87 951 engine and reseal 'kit' [Pickup in Seattle only]
I have a nearly complete 'assembled' 951 engine that came out of my '87 Porsche 944 Turbo with 165k miles on it.
It's missing the turbo and the wastegate. No wiring/ECU included.
Engine is partially assembled for ease of transport only, it needs to be taken back apart and gaskets installed.
Most everything was media blasted and degreased as I planned on powdercoating everything. Bores look great and it ran well before I removed it from the car. Car was leaking oil, hence the removal and plan to reseal the entire engine.
Has a brand new Zim's waterpump on it.
Rod bearings were also changed (preventative) right before I decided to just pull the engine.
Included alternator and AC compressor, but no power steering pump.
Includes a spare head that I started to press out the valve guides of even though the head installed on the engine is still in great shape. Have valves/springs for the spare head, they're just not shown in the pictures.
Also have a spare intake manifold.
Copper/MLS exhaust/turbo gaskets.
Exhaust headers have been DIY ceramic coated.
All nuts/bolts/etc are bagged and labeled.
I also purchased every seal (except for a headgasket and oil pan seal) to completely go through the engine. This includes every o-ring, seal, gasket, bushing, etc that is found on the engine. Includes the pricey oil pump, balance shaft, and cam sleeves/bushings. Also includes valve guides and valve stem seals along with an upgraded silicone rear cam gasket (the OEM gasket is crappy and always leaks even when new). This is nearly $400 worth of mostly OEM parts!
$750 for everything
Not really interested in trades unless you have some nice 5x130 Porsche or 5x112 Audi wheels.
If you don't want all of the gaskets/etc I will deduct $200, so $550 for just the engine.
Pickup in Federal Way, WA
More pictures and parts list on craigslist:
https://seattle.craigslist.org/see/pts/6143803838.html
Old 05-21-2017, 11:12 PM
alxdgr8
alxdgr8's Avatar
New link, somebody flagged the last one: https://seattle.craigslist.org/see/pts/6142169462.html
Old 05-22-2017, 12:23 PM
fortysixandtwo
fortysixandtwo's Avatar
Too bad you're 1200 miles away, otherwise I'd pick it up.
It looks like your new CL add has been flagged as well.
Old 05-22-2017, 12:37 PM
autosea
autosea's Avatar
Interested in engine and I live in Seattle
Colin
206 612 0444
Old 05-22-2017, 01:00 PM
alxdgr8
alxdgr8's Avatar
Colin, sent you a text.
I'll fix the ad later today, must not like me listing all of the part numbers for the parts.
Old 05-22-2017, 01:01 PM
alxdgr8
alxdgr8's Avatar
Also have stock flywheel, clutch, pressure plate that'll go with it.
Old 05-23-2017, 12:49 AM
alxdgr8
alxdgr8's Avatar
One more try, hopefully it doesn't get flagged again:
Old 05-23-2017, 12:50 AM
alxdgr8
alxdgr8's Avatar
---///Parts Included///---
Item Name Item Price Quantity Item Total
944-107-201-08-M67 $7.00 1 $7.00
Oil Filter
944-106-353-01-M6 $3.75 1 $3.75
Radiator Drain Plug w/ Seal, 924S/944/968 (1987-95), each Brand: Behr
900-174-044-40-M260 $3.00 1 $3.00
Dip Stick Seal, 928 - Brand: OEM
999-701-653-40-M17 $2.00 1 $2.00
Oil Cap Seal, 944 (1983-86), Each Brand: Victor Reinz
999-701-661-40-M17 $3.00 1 $3.00
Seal - Oil Separator/Filler to Engine, Lower, 2 required per car,
924S/944 all, Each Brand: Victor Reinz
999-701-613-40-M104 $3.00 1 $3.00
Seal - Oil Separator/Filler to Engine, Upper, 924S/944 all, Each
Brand: Corteco-CFW
10-0914-165-M30 $35.25 1 $35.25
Complete Gasket Set, Oil Cooler/Housing, 924S (1987-88), 944 (1983-
89), 944S (1987-88), Each Brand: Elring Klinger
- Prepackaged Gasket Sets are non-returnable if they have been
removed from their sealed factory packaging
999-701-652-40-M213 $2.75 2 $5.50
Balancing Shaft Upper/Lower Front O-ring, 944 All, 924S Brand: D P H
999-701-875-40-M17 $2.50 2 $5.00
Seal, Rear of Balance Shaft (2 per car, sold individually), 944 (1987-
89), 944S/S2, 944 Turbo (1987-89), 968 Brand: Victor Reinz
999-113-349-40-M17 $10.25 1 $10.25
Front Camshaft Seal, 32x47mm, 32x47mm, 924S, 944 Turbo, 944 (after
1985 cars with Eng# 43F06995 for manual trans and after Eng# 43F21203
for automatics) Brand: Victor Reinz
944-105-321-00-M17 $1.00 2 $2.00
Balancing Shaft Flange Gasket, Upper and Lower, 944 All, 924S, 968 -
Brand: Victor Reinz
999-701-602-40-M17 $0.75 2 $1.50
Cam O-ring Seal, 944, 924S, 928 (1980-84) - Brand: Victor Reinz
944-105-199-03-M17 $8.00 1 $8.00
Camshaft Housing Gasket, From Cam Housing to Engine Block, 924S (1987-
88), 944 (1983-88), 944 Turbo (1986-88), Each Brand: Victor Reinz
***Order #3***
944-101-233-02-M17 $2.25 1 $2.25
Oil Level Sender Gasket, 924S/944/968 All - Brand: Victor Reinz
900-123-007-30-M131 $0.25 1 $0.25
14 x 18 x 1.5 mm Sealing Ring for Early Style Temp Sender, and
Thermoswitch for Fan - Late-Style Carrera Factory Oil Cooler - Brand:
Fischer & Plath
N-043-815-3-M131 $0.25 1 $0.25
Sealing Ring, 20X24MM, 944 - Brand: Fischer & Plath
999-113-426-41-M204 $21.50 1 $21.50
Flywheel Seal, 924S/944/968 All, 911/911 Turbo (1978-89), 996 Turbo
(2001-03) - Brand: Kaco
900-123-140-30-M17 $0.25 7 $1.75
Gasket for Oil Temperature Sending Unit, 944, 944S, 944 Turbo, from
2/85 - Brand: Victor Reinz
944-105-199-03-M17 $7.75 1 $7.75
Cam Housing to head Gasket, 2 req for 928 (1978-84), 1 req for 924S
(1987-88), 944/944 Turbo (1983-89) - Brand: Victor Reinz
928-105-139-02-M260 $21.00 2 $42.00
Flange for Camshaft Seal and Balance Shaft Seal. Balance Shaft: 924S,
944S, 944S2, 944 Turbo (from 1989), 968, 944 (from Eng# 43F 06995 1985
Eng# 43F 21203 1985); Camshaft: 928 (through 1984); Both: 944 (thru
Eng# 43F 06994 1985 Eng# 43F 21202 1985), 944 Turbo (through 1988) -
Brand: OEM
928-105-139-05-M260 $36.00 1 $36.00
Flange for Camshaft Seal - Brand: OEM
944-107-161-02-M260 $40.25 1 $40.25
Oil Pump Sleeve, 944 from mid 84 - Brand: OEM
928-105-184-00-M260 $1.50 1 $1.50
Seal for Front of Cam Housing, 924S/944 All, Each - Brand: OEM
944-106-313-00-M260 $4.75 1 $4.75
Block Off Plate (water pump), 944 (1983-89), Each
999-707-283-40-M213 $1.75 1 $1.75
Thermostat Seal (for additional thermostat), 944 Turbo, Oil Pump
Sleeve O-Ring, 924S/944/968 All (1983-95), - Brand: D P H
999-113-331-40-M104 $9.75 1 $9.75
Seal, Front Crankshaft (Oil Pump) 38 x 52 x 7 - Brand: Corteco_CFW
999-113-281-40-M204 $9.75 2 $19.50
Balancing Shaft Lower Seal, 944, 924S, 968 - Brand: Kaco
999-113-282-40-M17 $5.50 2 $11.00
Balancing Shaft Upper Seal, 944, 924S, Cam Seal, 944 (up to 1/85),
924S/944/968 All, 928 - Brand: Victor Reinz
944-110-163-05-M17 $1.50 4 $6.00
Intake Manifold Gasket (4 per car, sold individually), 924S, 944
(through 1988), 944 Turbo - Brand: Victor Reinz
900-123-049-30-OEM $4.00 3 $12.00
Seal Ring for Oil Pan Plug, 924S (1986-88), 944 (1985-91), 968 (1992-
95)
- This is a special-order OEM part and is non-returnable except for
warranty replacement.
951-104-195-01-M260 $4.50 8 $36.00
Valve Stem Seal, 944 Turbo (1986-89), As Needed, Each Brand: OEM
944-104-328-51-M105 $5.25 8 $42.00
Intake/Exhaust Valve Guide, 1st Replacement, 924S/944/Turbo, As
Needed, Each Brand: Canyon
Old 06-05-2017, 08:01 PM
alxdgr8
alxdgr8's Avatar
Still available
Old 06-08-2017, 09:38 AM
marky522
marky522's Avatar
Damn, wrong side of the country or i would be all over it.
GLWS
Mark
Old 06-21-2017, 01:42 PM
alxdgr8
alxdgr8's Avatar
SOLD
Quick Reply: FS: '87 951 engine and reseal 'kit' [Pickup in Seattle only]
