Anyone successfully painted their fuel rail?
Professional Hoon
I've tried to paint mine twice. first time im not sure what i used, but it flaked off.
2nd time i used the hi temp engine paint. flaked off.
Options??
Options??
clean the rail with Naptha before painting it and give it a quick sand with scotchbright green or red pads.
I will post a couple pics of the stuff I use. I have 2 different brands.
If you're doing screw clamps or anything mechanical, make sure they're disassembled. My clamps are usable, but there's a gap in the coverage.
Nylon lock nuts won't survive the process. Aluminum doesn't work either.
Parts pitted with rust can be clad, but they won't look pretty. Most of my parts came out fantastic.
Naphta is regular diesel fuel or?
Warning...use in a well ventilated area or use respirator with proper filters....stuff will make your head explode
and possibly vomit ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Camp cooking stove fuel to the typical user. Eg Coleman
It's kind of a generic term for the type of fuel.
If you get one specific for painting purposes it won't contain anything that inhibits paint adhesion.
It's used as a final cleaning product prior to painting. Removes anything and everything except certain glue. Eg the sticky stuff under the hood insulation.
I just used the high temp engine enamel you can find a supercheap/autobarn/repco etc. It's held up well so far. I think the key is to clean it very well. I also scuffed it up with a scotchbrite pad and wire brush, and final clean with paint thinner.
I replaced mine because two in a row leaked at the welded seems where the mounting tab welds to the fuel rail. I had two locations leak on the top mounting tabs. You may just have a fuel leak just as I did. Might want to check ten times just to be sure. I'm not joking unfortunately. One of the best purchases for the best piece of mind was replace all the fuel components (besides the tank itself, yet) with new oem rear lines, new filter, 044 pump and up to date and better billet fuel rail (without welds) and supply lines with heat shield covers(very very important for some fire reason).
