Tough turbo decision... Still!
Well, I was curious about the backpressure question that comes up regarding the KKK #6 hot housing in particular, so I put a gauge on my car which has a K27/6. I was surprised that at 14 lbs of boost my backpressure peaked at 20psi. On the street my boost comes up very quick and will get max boost at around 3200rpm. Just another data point. Does anyone have the backpressure readings from a Garett hybrid?
dand86951
By backpressure do you mean the pressure in the cross-over pipe (between the header and turbine)?
I have bought a standard wastegate on eBay, gave it a new valve seat and shims and noticed that the valve begins to open at 10psi and can hold no more than 20psi at max flow from a typical garage compressor. Applying pressure to the top (intake pressure) will make the valve open at 6.0 psi. Without the shims the opening (intake) pressure is 4.5 psi.
I am interested in this, since I plan to “tighten up” the wastegate in a very simple and inexpensive way and knowing the boost/backpressure ratio becomes important with this scheme. More about that later if successful.
Laust
Laust
Tony
The dyno chart I referenced is not my car. It is some on who lives in colorado that has the same turbo. I have not had mine on the dyno. He had a intake leak that was later fixed and a autothority MAF that is not mapped for the TO4E (that and being at 5000 ft may be the cause of the slow boost build up on his car). I have several turbo cars and the lag at altitude is much worse than sea level, plus the turbo has to work harder to make high boost, But in the end its better than the 20% power loss the NA cars have at 5000+ ft (it is really bad at 10000 ft)
john
John
john
John
Rennlist Junkie Forever
jchaley
He must have had one hell of an intake leak!
What ever it was, his turbo came on real late for a basically stock car. Heck... that's where my turbo whips... but for me with my extensive modifications, it's worth it since I make peak HP at 7,000rpms.
For a basically stock car to whip on that late, and roll off at <5700 rpms, makes no sense, as the area-under-the-curve is way too small...
TonyG
TonyG
cpt. koolbeenz, The statement I made about the TO4B flowing more than the TO4E was from my research on compressor maps at various web sites .
When you take a 40, 50 , 60 etc, trim wheel , the TO4B flowed alot more.
Go to some sites and see for your self. I talked to David Lindsey yesterday and he said his engineer said the TO4E is bigger and runs a couple pounds more boost.
Every other person or mag. also said the TO4E was the big horsepower turbo. Maybe Tony G. can answer this , he knows alot about turbo's.
Mark
Mark
Also, the turbo I'm using is a TO4B w/ 60 trim and a KKK #8 hotside .
It flows 785 cfm's @ 1 bar ( 56 lb/min) and has the possiblity of making 560 hp ( of course not with my #8 hot housing).
I found this online here:http://www.turbonation.com/turbo.htm
A good rule of thumb for when there is too much back pressure is when the pressure in the exhaust manifold is more the half of the pressure in the cylinder. So basically, a larger A/R ratio will improve your engine's top end, while losing some mid range power and increasing turbo lag. A smaller A/R ratio will help the bottom and mid-range, but may effect the top end.
Cpt - give gatorbait a buzz, I think he is considering parting a new vitesse kit. If so that turbo would probably suit you fine. I know he needs money now so it might make a good buy. I told him to get with you as well, figured it couldnt hurt.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Originally posted by Laust Pedersen
dand86951
Laust
dand86951
Laust
Originally posted by cpt_koolbeenz
I was also told by Majestic that the number 6 hotside with the t04e would also have too much backpressure.
Good point Rob... I will ask Majestic about that.
What does it mean when half of the pressure in the cylinder? For exhaust or boost?
Where exactly is the test plug for the exhaust- I think it may be leaking?
Thanks Matt - good idea - hopefully he is easier to get a hold of than Tony
Ahhh - "It feels good to be a" member. Just payed - how long till it shows in red?
TonyG- Gave you another ring... Turbo, is it still for sale?
What do you mean by "half the cylinder pressure"? Average cylinder pressures could be 100 psi and when it's burning, it's alot more than that. So, that can't be what you mean.
Turbine dynamics are much harder to understand than the compressor ( CFM rules; that's it). In a nutshell, all that's important is the back pressure vs boost pressure. If back pressure is less than boost pressure, you will make good top end power. Im still trying to figure out if some valve overlap is needed to make the most use out of this concept. Tony, did you ever get your back pressure tested?
