Transmission re seal
Correct. Just lock the flange in place by putting a screw driver or something through the outer holes for the cv shaft bolts, then undo the central bolt. Slide out the output shaft and then pull out the seal. Quite easy to do. The only thing to look out for is that the right seal has a seat, whereas the left does not. So take care to install the left seal to the correct depth.
