rpm specific fuel cut
Old 01-09-2017, 11:04 AM
  #46
moalaska
moalaska's Avatar
Originally Posted by ealoken
Do yor engine loom from DME to injectors have any resistors?
I just tok my kit out of the car since im going standalone, and my kit has Resistors in it.
​​​​​​​Ive been running without resistors
Old 01-09-2017, 11:49 AM
  #47
Humboldtgrin
Humboldtgrin's Avatar
You need resistors if you're running stock turbo DME with low impedance injectors otherwise you will eventually burn up the injector drivers in the DME.
Old 01-10-2017, 01:42 AM
  #48
moalaska
moalaska's Avatar
Got my injector harness rebuilt, ill try and get out on the street and confirm if my issue is solved.
Old 01-14-2017, 01:25 AM
  #49
moalaska
moalaska's Avatar
​​​​Got my injector harness rebuilt, ill try and get out on the street and confirm if my issue is solved.
Update
Managed to go for test drive with refurbished plug wires.
Seems to run a little better, but still having same symptom, going lean, hitting brief flat spot between 2500 and 3000rpm. Im wondering if my alternator is causing issues. I know maf is very sensitive to voltage. When im running lights and blower belt squeals and when fans kick on voltage drops briefly causing afrs to go low/high. Belt is new and very very tight but still wants to slip under load even with belt dressing.
Also checked out dme connector it looks like injector connectors, exposed and corroded. So I ordered all of the connectors to do the temperature connector and reference sensors knock sensor idle valve and TPS. I'm also going to remove as much as the heat shrink as I can to inspect the wires and rewrap.
Yes I cleaned my grounds
May be excuse to do quest alternator.
I should be getting new plug wires and sensor connectors soon as well as injector resistors.
Also opened klr, it all looks good.
Old 01-14-2017, 11:52 AM
  #50
Humboldtgrin
Ok now change your distributor cap/rotor and spark plugs, fuel filter, air filter. Basically tune up your car then if the problem still exist then start digging into other items. Change your oil while your at it. And check your DME coolant temp sensor and IAT sensor to see if there in range.
Old 01-14-2017, 12:44 PM
  #51
moalaska
moalaska's Avatar
Yeah cap rotor plugs are new. Fuel filter, check valve new, screen cleaned. Tried 2 new dme sensors. Not saying any of those components couldn't be bad though. And oil fresh as i just resealed my cooler.
Old 01-14-2017, 01:28 PM
  #52
Tom M'Guinn
Tom M'Guinn's Avatar
Update
What is a refurbished spark plug wire? I'd get brand new, right out of the box, wires before chasing other things -- especially if wrapping them in electrical tape or whatever seemed to help a little. It's money well spent whether or not the cause of your current issue.
Checking the harness connectors and heat-shrunk connections is definitely time well spent too.
If the starter motor cranks strong without needing to be externally charged, your charging system is not a likely cause of this issue.
Old 01-14-2017, 03:34 PM
  #53
moalaska
moalaska's Avatar
took spark plug wires cleaned ends checked ohms and continuity and wrapped in heavy splicing tape. But i was just doing all that for diagnostic purposes to see if anything changed and perform other tests while i wait for new wires and connectors to show up in mail.
Old 01-14-2017, 08:10 PM
  #54
moalaska
moalaska's Avatar
Decided to check voltages at injector harnesses.
12 volt on one side 10 on other for all 4
Should i be getting any continuity between injectors 1/2 and 3/4? Are signal and ground wires seperated for the pairs do they share a common anything? I read somewhere on here someone had same voltage readings i think he had wires grounded out inside the snorkel boot
Quick Reply: rpm specific fuel cut
