Different Air/Fuel guage, Better???
Drive-by provocation guy
I was doing a search on EGT guages and found this place. They have air/fuel guages that are mechancial sweeping guages and not the LED style.
Not sure if these might be more accurate than the standard dithering lights guages for a/f.
http://www.frostalarm.com/cat/dp2.html
It's not the gauge that's the problem its the sensor. Those use a stock O2 sensor which has a voltage range of 0-1V as I understand it. The wideband sensors are 0-5V IIRC(might be higher...not 100% sure on that). Basically by having a wider range you have better resolution. That's why the cheap ones dither so much....they're measure 0-1V
Wideband setups are so expensive!
I was looking at them the other day, and OMG I couldn't believe the price they were selling at. The ironic thing is people are still going to buy them.
