1987 944 Turbo, both airbags deployed
Hey guys I need some serious help. I was out driving my 87 951 in the rain. I have never had a problem with my car sliding or losing control in the rain or snow. So I was coming up to a curve to get off a main road and I downshifted. After downshifting one of my back tires locked up and I slid off the road into the grass. That would have been fine, but with my ****ty luck there was a fire hydrant there. My right front corner hit the hydrant and both air bags deployed. My entire front trim piece came off, the right side bumper mount is pushed in and bent the metal behind it inward toward the radiator. The car started right back up and there doesn't seem to be any mechanical issues. I picked up my front bumper cover, put it in the hatch back and drove 30 minutes home. So now my windshield is shattered, the right headlight mount cracked in half, the passenger's side dash and glove box area are all bent up, I need a new bumper and mount along with the bumper cover and right fog light. Is it even worth spending thousands and thousands just on the airbags and it's system. I don't even know where to get new airbags. I didn't have collision because I was just about to switch to classic car insurance. So I have to pay out of pocket. I spent the whole summer rebuilding the head, HG, ARP head studs. Vitesse MAF, Fabspeed Exhaust, 55 pound injectors, larger Broadfoot turbo. So I'm sick over this. Can anyone give me advice about if it's worth putting in new airbags and how to fix the steering wheel and dash where the bags came out. Thanks, Kevin Anderson
Basic Sponsor
No is a goner send me a text
Luis are you serious? It's just damage to the front right corner and the airbags went off. There is no way it's totalled. I drove the damn thing 1/2 hour home. Yeah it's a couple thousand dollars in parts and work, but I don't think it's ready for Larts Graveyard Don't F with me like that, I'm sick about this as it is. If it did get parted out, I could definitely get a nice running 951. The head, turbo, innercooler, exhaust and Vitesse MAF would sell for around $4000, then the Konis, springs, newly covered seats, rear Hatch, DME, KLR That's another $2000. Maybe I will send it to you. You've parted out cars nicer than mine.
The worst damage is from the right bumper shock pushing the metal it mounts to back an inch. Also about an inch from the strut tower the metal is crumpled, probably from the bumper shock being jammed back. All the rest is bolt on stuff. Do you think a good bodyshop can pull the metal forward? I've seen those frame straightening machines fix pretty messed up frames. I just need about an inch pulled forward on the right side. I'll take pics tomorrow. It's just my luck. If the hydrant was in a different spot I would have slid on the grass and just kept going.
I've gotten some good offers for air bags. The damage that bothers me is where the frame buckled under the power steering reservoir. I hope the body shop I'm taking it to can pull it straight out with those big racks they use for frames. It was the bumper shock being pressed all the way in that caused it. I've seen cars looking 5 times as bad as mine leave the shop as iff nothing happened. Most of the parts are bolt on. I'll buy one of those nose clips so they can just use the metal from that. The radiator isn't leaking and the fans work. I'm still sick about this. If that hydrant was 10 feet away, I would have slid on the grass and kept going.
Basic Sponsor
Kevin, let me encourage you by saying that I.............................
Luis you didn't finish what you were going to say. If you have a good 951 roller with no engine or anything I wouldn't mind putting my engine and seats in it and you could carve this up. Thats if this is DOA.
