88 951 3L 456rwhp
Ok guys up for sale is my 88 951 most of you have seen the build going on and such ... Anyways it's up for sale $19,000. It's 90 percent there it's turn key and drive .. Pulls hard . Albert built my 3.0l installed and tuned it over at mase.
Had the car checked out at motor werks in GA before it shipped to me and after a few test told me motor was good to go and I had it shipped to New York. Car will need new shift Linkage it's sloppy and limp, AC compressor is bad and a power steering line is leaking not much but still ..
Anyways here the mod lost I do have pretty much all documents to support it
Engine
JE pistons
88mm crank
Carillo rods
Negotiate o ringed block
Dayton sleeve 103mm
Oil pan baffle
Ported and polished head
Custom grind race cam
Bigger valves
Custom intake manifold
Electromotive tech s EMS
6262 with billet wheel
Lindsey 3 inch full exhaust
Tial wg
Electronic boost controller
1000cc injectors
Dyno tuned 463 wheel
All new belts and bearings in motor (complete rebuild)
Suspension/brakes / steering
Koni yellows
30mm front seat bar
Elephant racing control arm bushings and caster mounts (done 100 miles ago)
Zimmeman cross drilled (done 100 miles ago )
Hawk hps pads (done 100 miles go)
Rennbay ball joint kit (100 miles ago
Alignment 100 miles ago
Power steering rack is about 5 years old (rebuilt one )
Body
Fiberglass front end
3m wrapped
924 hood
Carrera light weight 18s with brand new tires 285 rear 225 front ( hairs still on sidewall)
Trans
Rebuild 5 years ago
Custom axles and cv joints (not installed)
Custom trans brace (not installed )
PRICE $19500
Engine
JE pistons
88mm crank
Carillo rods
Dayton sleeve 103mm
Oil pan baffle
Bigger valves
Tial wg
1000cc injectors
Koni yellows
30mm front seat bar
Body
3m wrapped
924 hood
Trans
Rebuild 5 years ago
PRICE $19500
Why are you selling it now? Had enough of everything? That's a steal. GLWS
Originally Posted by e34nication
+1. Get all the leaks and tune figured out? ... Or cutting losses?
If you can put it in a garage somewhere and forget about it for half year or more, you will love it after a certain period. You will also probably regret selling it.
Originally Posted by ian
Per the question above. Did you get all the leaks and tuning issues worked out? If not what problems still remain?
