At what point are the stock fuel lines a limiter?
Out of curiosity. Running e85, having to upgrade to a fuelab pump for more flow. We're installing -8an feed lines -6 return
What big engine e85 guys have had to do this?
lines replaced with ptfe based lines. the return line is now leaking at the fuel sender. Need to figure out a better way to attach. Apparently pushing the ptfe line over the fuel sender hose and using a clamp wont seal
