Is this a bad tps at idle? 83 ohms
I have been trying to track down a bad and lean idle for the past year. I previously swapped out the tps with a supposed used working one a while back. I am trying to retest everything again to track down the problem. According to Clark's the ohms should be 0 to 10 with the throttle closed. Mine reads 83. is this a bad tps that could be creating way lean lumpy idle. Done pressure tests numerous time to the intake but can't find any leaks.
Ok so pins 4 and 6 on the switch are zero omhs when throttle closed. Does the fact that there was some resistance at the dme connector indicate a wire problem?
