TPS mounting position????
Drive-by provocation guy
The front mounting screw for the TPS has some degree of play for mounting. I guess about a 1/4 inch.
Where should you set the postion before tightening the screw down?? All the way forward?? back, in the middle?? This movement also varies the revs/idle.
Your TPS shoud be adjusted so it produced a small "click" when you accelerate from idle (just move the cable with the hand and motor off to test) ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
This "click" enables your TPS to go from idle mode to normal mode.
Originally posted by toddk911
So I guess every car would be different ?
BTW one screw is just about impossible to get to with the tyhrottle body attached to the intake, take the whole throttle body off & it's much easier to get to & adjust accurately.
If so the idle won't stabilize correctly because the car will not make the proper mixture (if it doesn't know if you are idle of normal) ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
That's really easy to set up. Just put your TPS in place and try to move the accelerator cable. It should produce that little click immediatly
Take a look at the Lindsey Racing site (http://www.lindseyracing.com/) under "tech garage" for a step-by-step description for setting the idle, including adjusting the TPS. Clarks Garage (http://www.clarks-garage.com/) has a pretty good one too... as noted, it's not that tough.
