Plumbing to carbon canister necessary on track car?
Need to replace a clutch master cylinder, and the tubing for gasoline fumes to the canister in the driver's side fender is one of the things in the way.
For a dedicated (will never be street legal again) track car, is there any need to replace this plumbing? It would appear that some gas and vacuum lines would need to be plugged.
Some A/C lines are also in the way, but the rest of that system is long gone.
Also, any tips on replacing the clutch master cylinder?
On my car I removed it and put a little breather filter on the breather line in the rear right wheel well. Just cap off all of the vacuum lines. I pretty much cleaned out anything that didn't make the car go.
