104mm bored head gasket
I upgrade my 951 to 2.7l with a 104mm bore. The problem is there is no 104 mm head gasket to match. I found only 103mm or 106mm mls cometic gasket. What is the better match????
By my measurements, the fire ring inside diameter on a standard 944/968 head gasket is 2mm bigger than the bore. So the head gasket for a 100mm bore has a 102mm opening, and the head gasket for a 104mm bore has a 106mm opening. So that 106mm gasket you found might be just what you need, if you mean the fire ring is actually 106mm across.
Edit: Just noticed you are talking about MLS gaskets. I was referring to standard and widefire gaskets, not MLS -- so worth a call to see how they spec the opening relative to the bore, as it may or may not be the same.
Freedom Enthusiast
