half-price Koni strut conversion, 87-88 944 Turbo
Two sets available for immediate delivery.
I have two sets of mismatched 87-88 944 Turbo struts that need to make room for complete sets. Per set, one strut is from the 87-88 951 while the other is from the 86 951.
The offer is for 1/2 price normal conversion ($55/pr v. $110/pr) plus the cost of the 8641-1414S and normal s/h. Can be modified for use of adjustable ride height kit (lower perch removal, +$25/pr).
The differences are slight, but noticeable. They will fit with no modification and actually came from 87-88 951's. The differences are: brake line tab is mounted on the lower spindle clamp horizontally (86) verses on the body at a 45 degree angle (87), and the accessory mounting tab (for ABS harness, pad wear sensor harness) are oriented slightly different. For concours prepared cars, this might be a hit... all others is simply a slight visual difference. Both have identical brake duct mounting tabs.
Email me directly for details: skip@paragon-products.com
Thanks!
Thanks!
I am interested in them. It's for an '86 951. Are you still on Whidbey Island? email me at bvbrown@fidalgo.net
