6 speed conversion
6 speed conversion
I have bought a 968 six speed plus the axles and the linkage and I'm wondering what additional parts are needed to to do a successful conversion for the 944 turbo. Also, does anyone know how to reactivate the speedo? the 6 speed trasaxle does not have the tap for the speedo.
TIA
JPR
TIA
JPR
You got all of the parts you need for the conversion. There is a way to make the Speedo work based on the ABS signal.
The guy I know at Stuggart Auto Haus swears by his 6 speed conversion. the speedo does not work in his to my knowledge.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
If you don't have ABS, there was a post a while back regarding this subject. A racer in CA did the conversion by installing a trigger wheel at the half shaft and added the electronics to convert the signal...
Search the archives, hopefully the info is still accessible.
Good luck, let us know how it goes!
Tifo
I have the 6 speed conversion in my 1990. The wheel sensor is picked up from an extra gear placed on the half shaft and using sensors from terratrip (a rally navigation system) with a converter box in the middle to accurately calibrate the speedo. The gear came from a Lamborghini Muira S, if that is any help, which I doubt it is.
Hmm... why dont you use the stock 951 pick-up sensor with the magnet from an old tranny? (i think its a magnet mounted in the dif) then mock up a mount for the sensor off the tranny, over the cvjoint, and tie wrap the magnet to the cvjoint, to see if this will work. if it works, JB weld the magnet to the CVjoint and add a counterbalance to the other side of the cvjoint.
Sean
Sean
