FS: TO4B-H3 turbo
FS: TO4B-H3 turbo PRICE DROP
I bought this to use with my 3L motor and after looking more closely at the compressor map it's going to be far too small for my application. Good used condition, no shaft play I could detect. I never ran this on my car but it was removed from a running car. KKK CHRA and a -8 hot side. Compressor wheel measures 58mm/70mm. Doing some research through Google shows it's good for around 350hp at the wheels. Uses stock -8 hot side so it will bolt up to the factory down pipe and crossover.
UPDATE: This turbo will need a rebuild. The shaft does not spin freely like it should. The shaft still turns but doesn't rotate for 3-5 seconds, only for about 1 full revolution. Price dropped accordingly.
$300/shipped to CONUS
