Tach signal for innovate SCG-1
Has anyone had success hooking up the tach feature on the innovate SCG-1? I tried the coil signal wire but it doesn't seem to drive the tach in the gauge properly, it's very inaccurate.
Just found this but it's for a Zeitronix ZT-2:
Wire 1 (red): connects to DME pin 18 (red/yellow) or other switched 12 volt source
Wire 2 – not used
Wire 3 (green): connects to DME pin 21 (green, RPM signal)
Wire 4 (orange): connects to boost sensor’s green wire
Wire 5 – not used
Wire 6 (yellow) connects to boost sensor’s red wire
Wire 7 (black) connects to DME pin 5 (brown, ground)
Wire 8 (brown) connects to boost sensor’s black wire
Wire 9 – not used
Wire 10 (grey) connects to KLR pin 22 (white/green, TPS)
Wire 11 – not used
Wire 12 (blue) spare input I connected to MAF DME pin 7
Wire 2 – not used
Wire 5 – not used
Wire 9 – not used
Wire 11 – not used
