How to fit my 18" rims
i just want to ask what for spacers or otherthings I will need to fit my new rims (10Jx18H2-ET58 and 8Jx18H2-ET57) on my Porsche 944 Turbo from 1986?
Thank for the help
Thank for the help
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
Or get a membership and ask the listers, you may get a better deal in the end.
Aside from spacers / longer studs it is highly recommended that you update the caster blocks to the 968 part. Also make sure the bushings / ball joins in the suspension are in good shape, the large 18s are going to put a lot of added stress on the suspension.
I have the same wheels. I run 1" spacers on all 4 corners. With soft (stock) suspension it'll rub a tiny bit on the inside of the wheel well in the back when accelerating and hitting a bump (like an expansion joint on a bridge). It's gotta be both accel and bump at the same time, other than that they don't rub.
Also the car is slower. You'll feel the difference because of the weight and higher inertia of the wheels. And it's not as comfy. Pot holes and bumps hit pretty hard compared to 16's. But they look fantastic!!!!
Freedom Enthusiast
Thank you all for the help
I just found another problem... This one is my english.. It's not the best..
944Phil if you want could you write me an e-mail I will need some more help to understand everything I need => grb94@live.fr
(Maybe if you want send me some pictures about your 944 with this wheels so I can see how it will look in the end)
When someone else wanted to help me more just write me
