Help-Lindsey Ultra motor mounts
The car is a streetable track car(drive it to the track)
Need advice on how many spacers to run?
Do not want to bottom out the pan on back roads getting to the track.
How many spacers you folks running?
If I remember correctly I'm running 1 spacer, not too low, haven't banged the pan on anything yet, even after an off road excursion at streets of willow. Make sure to torque the hell out of and red thread lock the main bolt or it will spin when you torque it in the car, and then you have to pull it back out and start again. As well as lifting the engine I also had to drop the front crossmember to get them in.
