Racetronix injectors. What am I missing?
Done With Sidepatch
Try this recent rennlist thread for details...
I haven't done it yet but I plan on mounting my resistors on a piece of aluminium like this image from Guru Racing
and then wiring the resistors into the gray and gray/black wire exiting the DME box.
Easy!
Easy!
Why do you need resistors on the same injectors that Lindsey sell without resistors?
If you use big injectors with short duty cycle I suppose you will have less heat develop in the control box as well.
BB
BB
"Why do you need resistors on the same injectors that Lindsey sell without resistors? "
V=IR
"If you use big injectors with short duty cycle I suppose you will have less heat develop in the control box as well. "
It's not just the average current drain over time that counts, but the peak current-draw during the initial opening blast that'll over-drive your injector-driver transistor. Some background on ballasts with the Motronic DME:
944 Turbo Injectors
what is the best 55 lbs Injector for the 951?
DME and relays getting hot
V=IR
944 Turbo Injectors
