Sway Bar Stiffeners
These reports of bent triangulated drop links sound strange to me. I've had these installed on my 968 autocross car using full delrin front bushings for several years and had no problems. When they bend, I wonder if a potential cause is how the front SB is installed since technically it shouldn't be preloaded, however this is difficult to achieve in practice (unlike the rear SB) since the front wheels are removed for easier access to the outer mounts at each control arm, hence the car is up in the air and presumably on lift or stands. When the car is brought down again, the links are likely prestressed which only becomes worse with high suspension loading.
It's also possible that the stiffeners and delrin work well with factory bars like m030 but expose poor articulation with aftermarket bars. I'm increasingly suspect of all the aftermarket junk which is designed to just barely fit and perform to a standard that's just 'good enough' (not to mention marketing maxims of bigger = better, stiffer = better).
I'm of the opinion that it is critical to make sure the sway bar is not binding in the mounts too. When installing the Tarrett bar, it is really easy to torque down the inner mounts so the sway bar is being slightly bent. If there is a bending load on the bar, then it binds in the bushings and I could see that easily bending the mounts with loading of the suspension.
At this point I've left the bent ones on. I figure it's stiffer than without them and I'm probably stiff enough for my use.
I bought factory 30mm 968 M030 bushings from Ian off of eBay. The inside ones have some kind of fiberglass reinforcement on the inside because there so thin I'm guessing. I have yet to test them out on the road. But they are high quality. Is the car with the bent supports lowered without using longer spindle pins to keep the control arm in the stock angle?
My car isn't lowered. If I ever upgrade the springs I will try a new support bracket. Until then I'm just writing it off as too much stiffening of the SB without other suspension upgrades.
