87 turbo part out
87 turbo part out
Hello all,
So I will be parting out my alpine white non-sunroof 1987 turbo with brown interior. It's got 131838 miles on it, "10 footer" re-spray in original color at some point. Interior is pretty much mint, but is not all out of car just yet. Have already pulled some parts out, here is a list of what's been pulled. Have more on the car yet to pull, let me know what you need and I'll see if I have it.
Drivetrain, wheels and front seats already out and not for sale.
Prices are shipped in lower 48 (except for transaxle)
K26/6 turbo, no shaft play, newer studs 225
M474 shocks and springs, used but not blown 450
AOS transaxle from 1991 S2. Pulled @ 82k. RH output shaft bearing will need replaced, pulled because noticed few drops from output shaft seal 500
Lloyds floor mats (brown, fronts only) 65
Hella 7 inch lamps for H4 bulbs, with new blue H4 bulbs 75
Set of 4 Hella 90mm lights used in my GT light conversion. 2 lows and 2 highs all with H9 bulbs 130
4 light buckets (no covers) with 4 sealed bulbs and one bar 35 per bucket with bulb
2 light bucket covers in alpine white (respray) 30
Stock wastegate (broken studs) 45
Stock fuel rail with plastic cover (no damage) and 2.5 bar fpr 75
Air Flow Meter 50
2 headlight motors 45 each
2 sets of stock front turn signal lenses (above foglights) 25 each
Air Flow Meter 50
bump
Everything is obo, if you want it, make an offer.
I have the buckets, lexan covers and iceshark harness for the GT light conversion as well, they are a little primitive but they worked for me. (also have a spare uncut sheet of lexan too.) Everything including the four hella 90mm lights 220 shipped in continental US
Don't manage that south very often, I'd say 100 bucks plus whatever shipping would be. I can pull it off and measure it today and get some kind of quote for you, if you'd like. I should be able to ship it out from my work which would be cheaper than normal.
