Boost guage connection
Gonna install an autometer boost guage, T-ing into KLR line in passengers footwell, and going to a-pillar pod. How does the nylon tubing go into the back of the guage? Do you use one of the fittings that came with the guage?
TIA
TIA
Back of the gauge should have a threaded fitting, and there should have been a threaded cap with a hole in the middle and a brass ferrule included - you slide the hose through the threaded cap and then slide the ferrule onto the hose, then insert hose into the threaded fitting on the gauge, then slide ferrule down against fitting, and screw the cap onto it with some teflon tape to seal the threads.
Sam
Sam
