How much hp: test pipe vs. straight pipe?
What would be an educated guess for the performance difference on a lightly modified 951 of
1. bursch test pipe vs.
2. exhaust OPEN right after the WG tie in?
Thanks in advance.
In case you're wondering, I am toying wtih the idea of putting a valve that can be open and closed to exhuast to atmosphere directly after WG tie in.
Thanks in advance.
#1 - maybe a slight decrease in spool time. if your stock cat isn't 100%, it will be more apparent
#2 - a .000001 increase in hp and 100 dB increase
Peckster, I'm not sure which you're referring to. On the Hayabusa, aftermarket pipes are worth a solid 2-3 hp after the computer is remapped for them.
Sam
Sam
The canister on a bike is good for nothing, the entire system with rejetted carbs is good for quite a bit. 2-3HP on a 'busa is like adding 1 HP to your 951, nice to say you did but not worth much in the end. Sam - do you have a GSX1300R? They are rocket sleds in a straight line, but I didnt like the feel of it around town.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Matt, my dad's got one of them, he really loves it - btw, no more rejetting carbs on the newer bikes, it's been full fuel injection for years. Ours is stock, as you said, 3hp is really nothing and my dad doesn't want it any quicker.
Blueman33, try looking at an electric exhaust cutout, that's the most convenient way to run a cutout, my friend has a pair on his Lightning for the drags. As for the difference, you'll spool quicker with the cutout, so gain some torque under the curve, but overall hp should be the same.
Sam
Sam
Boy, I really have to disagree with your comment about loud pipes, at least as far as Harleys go. Swapping from the stock pipes to a set of Kirkers on my FLHTC made a good sized difference, documented on a dyno, to the 5hp peak, and GOBS of useable torque. Granted, on some of your "superbikes", the factory exhaust is already pretty well tuned.
To answer your original question, blueeman, the key is the phrase "lightly modified". It won't make any difference, performance wise, for you car. If you want to get LOTS of scutiny by the local gendarmes, its definitely the "ticket"! lol
Regards,
Regards,
Scott,
I'd turn the thing OFF for the cop and say, "what? that noise was a Harley, you didn't see that thing go by? that wasn't MEEE"
You see, with the flip of a switch the valve opens and closes..........or even opens half way. I would open it for track.............and maybe once in a while on the street just to be a nut.
But it seems like a waste of money if it's just going to m ake the car sound obnoxious
Re: How much hp: test pipe vs. straight pipe?
Thanks in advance.
Thanks in advance.
233RWHP 238RWTQ
