Lowest price for Stock 951 injectors?
Originally posted by Mike B
I'm picking up a set of new, flow matched Siemens 55#ers from Racetronix at $49.99 each!
To be 100% accurate you need the 1.32ohm, however the 1.0ohm works just fine...
You are looking for TMS10-1.0-ND (Aluminum housed - 10W - 1ohm) resistor.. Get few extra as spares...
There are a few companies out there that supply them. You could heat sink them to a piece of Aluminum and away you go.
Anyone have pics of what the resistors look like?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
I got a pair of resistors separetly from Newark for like $15.00 shipped.
The Newark number for the resistors I got is 01F9895. These are 1 ohm, 50 watt resistors.
As for mounting, I just modeled my installation after the GURU RACING resistor package.
Rob
Rob
Done With Sidepatch
Hey MIke...
Ironically I ended up finding a source locally but I still ordered mine from Guru. A few months ago I was tossing between Vitesse Stage 2 and Map 2 but I decided on Vitesse. I still thank Danno for lots of great advice and I still ordered the Ultimate Head Gasket and Resistors just cause I felt I owed him for his time and knowledge............strangely enough they arrived 2 months later ... hehehe .... anyways
If you can imagine the resistors can be had for even cheaper. Check in the yellow pages under electronics. If you are lucky one of these electronic stores will have a few kicking around. If he has to order them you may have to pay a little more.....
P.S Make sure that if you use slip on connectors with them to at least tie-wrap or tape them down. In my last autocross I had my car flying around so hard one of them came loose. Let me tell you its not fun ending a run with only 2 holes firing .......
Yup..... at the DME is the easiest. JUst remove some of the tape from the harness. In an ideal world you should verify the pin numbers (check your workshop manual, As I recall it was a gray and gray/black wire at the dme). Tape it down tightly. If you need more specific details PM me.
