3bar Fpr
I'm intending on buying the Guru chip upgrade kit but buying my own 3bar FPR since his one has a clamp on fuel hose fitting and mine is a threaded connection.
I've heard the FPR from the S2 or 968 is set to 3bar and will fit the later 944turbo with the treaded connection.
Can anyone verify this and does anyone know a part number.
Thanks in advance.
Kenny
1991 944turbo
Shetland / UK
Thanks in advance.
Kenny
1991 944turbo
Shetland / UK
I've seen adjustable FPRs out there with threaded connections, I sure wouldn't cut the hose and go to a hose clamp, that's a huge step in the wrong direction.
Sam
Sam
Why bother with cutting the hose,when you can buy a genuine Bosch 3 bar fuel pressure regulator that bolts right up for 49.40$. If you need one,give me an e-mail. we have a few in stock
MySwiss,
I dont want to deny you any buisness but is there any chance you could supply me with the Bosch part number for the 3bar unit so I can find one in the UK?
Please reply to kalferhame@btinternet.com
Cheers Kenny
Cheers Kenny
