Won't run unless I pull the fuel pump fuse
#32
Jakob, my apologies; I forgot about this. Just went out to see. To my surprise, both sides of my injector plug show 12volts key on engine not running!
Chris.. if you're reading... is this correct?
#33
Dan that reading is correct. The reason is because you left the other four injector harness plugs connected. The circuit needs to be floating in order to track the short. I went and did the same thing again but with the 3 injector plugs still in and also got 12V on both sides.
If you try it again disconnect all 4 injector plugs and then you’ll be able to see 1 side 12V and the other side should have no voltage reading
#37
Dan out of curiosity did you measure continuity? I’m assuming that if you have voltage on both sides, you must also have continuity. My logic there is the wires have to be able to carry a charge continuously otherwise there would be a break in the circuit and you wouldn’t be getting any reading at all.
#39
No worries! These two tests have saved me sending out my injectors and buying an ECU so far so lol. I went back and reread the LJET thread entirely. I still believe there’s an electrical issue somewhere but probably not where I’m looking we will have to see what Chris says to confirm.
Theres an issue happening thats being distributed to all 4 cylinders. The mechanical components of the fuel and ignition systems are working. Leak down test was successful. Each injector physically works and isn’t stuck. The car only runs when the pressure is fully bled from the system and that can only happen two ways. The injectors fire and bleed the pressure, or the car bleeds pressure over time after sitting.
Carbon on the plugs and raw fuel out of the exhaust means too much fuel. So it’s definitely something that’s either not talking right to the DME, or the DME isn’t talking right to the injectors. Their could be a short in any of the other circuits that control the AFRs either in the harness or the computer.
Narrowing down it seems like at least.
#40
Hey guys,
Sorry for the delayed response, I have not had much time to browse the usual forums lately . . . .
Anyway, +12V at both injector connector pins with the ignition switched on and and while unplugged is normal. Remember, voltage is a measure of the difference in electrical potential between two points. If there is 12V on both sides of the injector coils, there is no difference in potential and therefore no current will flow when the circuit is completed. If one side is switched to ground, that will complete the circuit and current will flow.
The fact the Jacob has ~11V on one side and 7V on the other side (open-circuit voltage) means that there IS a difference in potential between the two sides of the circuit and current will flow when the connector is plugged in. Plug in an injector and it will likely click open (partially).
I think you have a bad DME, but unplug it to see if your voltage readings change (injector 12V+ is provided by the DME relay, not the DME itself). If they change, DME is the culprit. If not, it is a wiring issue.
Send in your injectors anyway if they've never been cleaned, it is well worth the effort. I recommend RC Engineering in Torrance, CA.
#41
Chris, thanks for the input. Since testing the injector harness I went through every single sensor harness plug yesterday and tested looking for any shorting or signs of an issue and couldn’t find one, even with the disgusting shape the harness for the speed and ref sensors the numbers are still bang on.
I physically pulled each injector and tested them direct to the battery and they each clicked.
Half of the sensors are new or replaced and the others have outputs within spec so if it is electrical I agree with you and Dan that it’s gotta be a DME.
I didn’t know that unplugging the AFM makes the DME run a different air fuel map. Even with my new one unplugging it helps the idle. So if it runs good on one map, their could be internal damage in the DME circuitry on the regular map.
I finally found someone who’s got a DME they are willing to lean me to test out so that should be a pretty definitive test.
Once the cars running, I’ll treat her to an injector cleaning lol and a new set of tires since mine are now lopsided from sitting.
#42
Wow cool info Chris, thanks.
Curious... when testing one injector connector while the others are plugged in, my reading is even +12V both pins. With all plugs disconnected, the same plug drops to 10V on one side; not as drastic as Jakob's, but a drop nontheless. Normal?
I'm chasing a long-running issue that is slight but... perhaps the infant stages of something Jacob is getting.
Looking forward to the DME swap test!
#43
#44
Jacob, it's a long-running issue of cold-start first 2 minutes hesitation with recent occasional popping in exhaust off-throttle upshift (not sure if related).
New-ish spark plugs are already carbon fouling. All else running well. Over the past year, I have improved upon lots of things and changed out many of the parts that could be related. I seem to fix everything but this stubborn issue just won't die!
It's mild enough to ignore but don't we all prefer to have a period of "zero-issue" lol
