Water pump failure, Engine Grinding noise at idle
I replaced the water pump, belts, and idlers about 12 months ago. At idle the engine is making a bad noise. Thought I had a bad idler bearing. On tear down, the water pump bearing failed. The water pump shaft has visable play and grinds when turn by hand. The belts were at proper tension.
I do not have the pump out yet, later today. I am not sure which vendor I purchased the pump from. But I spent a little more and ordered an Airtex pump. The GMB pumps are available for less the $100. The GEBA and LASO pumps are $300-500. What are you guys using?
I'm also in need of a "new" water pump. I spent a lot of time trying to track down a leak which I thought was from the gasket. It would not leak under pressure (testing at 15 psi) but I would end up with a small drip after a drive. Replaced the gasket and it's no better. Now I'm thinking it has to be the shaft seal - only leaking at higher RPMs.
If you are going with rebuilt, most seem to swear by Zim's. Having said that, that is what I bought during my rebuild. Surely the frequency of which I drive the car (i.e. never) is not helping the seal's life.
I am now going with a new OE pump or another $114 rebuild from Zim's and hope I get lucky this time....
I've had good luck with a "Porsche Certified" water pump rebuilder. The company is out of southern California and their business name is APR Pumps. The owner or contact person is Jaymes Layton 951-777-4993.
They built a few pump with a metal, multi paddle impeller that is a better design to the full faced impeller commonly used.
Good luck
Good luck
