Feedback for M-tune's latest chip
Last Saturday, I was enjoying a beautiful day on the porch when the mailman handed me an unexpected box. The strange box contained an eprom chip and a brief explanation from Joshua.
For weeks, I had been struggling to make the car comfortable to drive. I could not get my idle to come down from 1500 rpm when the engine was hot ( verified with a timing light ), and my AFR at idle were 12:1. I reset the idle, checked for vacuum leaks, pressure tested the intake, checked fuel pressure... It was very frustrating because everything was new, and the engine was rebuilt. Anything that was rubber was replaced.
I decided just to live with the issues because I just didn't have any spare time to spend working on the car, and frankly, I was annoyed with it and burned out.
Last night, I popped in the chip and everything was better. The AFR dropped to 14.8-15 at idle, the idle itself was about 1100, and the engine ran much leaner ( about 12.5:1 under full load ).
If you have the chip laying around, take the time to install it.
Thank you Josh.
Thank you Josh.
Quit Smokin'
I don't know what Josh is recommending these days, but I would give yourself at least 3% back with the FQS. 12.5:1 may be ok at WOT but I know I would much rather see 12.0 or really high 11s.
Updated chip is in my car as well; I'm seeing AFR's in the 11.5-12 range which I'm happy with. I have had some issues with a hard cut happening under high load at low rpm's (think 80+ % throttle at 2,000 - 2,500 rpm's) and the car consistently cutting under boost when it's raining. This weekend I'll try to capture it while data-logging.
Josh's letter recommended turning the switch back to the zero position with the updated chip. I'd say to try that first and adjust if needed for your particular setup.
As I was just typing that I had a interesting thought. If the fqs is setting a percentage difference from position zero, say adding 3% fuel. It would first calculate the zero position fuel quantity then calculate 3% of that and add that much more fuel. I wonder how much longer it takes the dme to calculate this. Being that its constantly calculating and adjusting its fuel ratio. Probably talking milliseconds but its something. The dme will be working harder when it not at position zero, again this is extremely fractional.
It just adds it to whatever is in the base table. I'm sure the software routine always does the addition (base table + modifier = actual pulsewidth) it's just that at FQS 0 it's adding 0 for that portion of the modifier. It's always doing math based on boost, intake air temp, coolant temp, etc.
If fqs = 0 then fuel = table
Else if fqs = 1 then fuel = table + modifier %
Else if fqs = 2 then fuel = table - modifier %
End if
I also have a Vitesse camshaft. I dont remember what the specs were, but the engine continues building power past 6000 rpm, which is too bad because I'm worried about spinning a rod revving any higher than that.
The reason I bring that up is the camshaft probably has characteristics which would make the car run a bit richer before reaching its power band.
Has anyone filled up their tanks with E85 yet? I used settings 3+4 and wired in a toggle switch for the E85 map. My only problem is that E85 gas stations are 20 miles away...
I noted that the latest update on the LR site indicate that Josh has been busy making improvements that has a long and wide application.
Not a customer - yet, but it is clear that based on his diligence on continued product improvement I will not hesitate to make this my next major purchase (turbo comes this week!).
