A-tune help needed
Old 08-09-2015, 03:34 PM
eman930
eman930's Avatar
Unhappy A-tune help needed
Hey guys, trying to get my 86 951 back on the road after a rebuild, I had it running yesterday on some Max951 chips, decided it's time to convert to a 28 pin and A-tune, so I modified the the DME, added the 4 pins and jumper wire, then cut the resister per A-tune install instructions, wired in my Map sensor, checked the voltage readings, I have 5 volts on the red wire and 1.7 on the green wire, went to start the car and she won't start, just cranks and cranks, any ideas on what to check?
Old 08-09-2015, 03:38 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Did you swap the updated chip to the chipboard?
Old 08-09-2015, 03:54 PM
eman930
eman930's Avatar
Yes, the chip you sent me I install, I just swapped it back to the old A-tune chip and no dice
Old 08-09-2015, 03:56 PM
eman930
eman930's Avatar
I just check continuity on my jumper wire and chip pins and they are all good
Old 08-09-2015, 04:17 PM
Rogue_Ant
Rogue_Ant's Avatar
Can you email me a picture of the chipboard installed, and the underside (solder side) of the board?
Old 08-09-2015, 04:18 PM
eman930
eman930's Avatar
Yes, what's your email
Old 08-09-2015, 04:23 PM
eman930
eman930's Avatar
I just sent pics to the email on your site
Old 08-09-2015, 04:34 PM
eman930
eman930's Avatar
I did turn the FQS all the way counter clock wise would that effect anything?
Rogue_Ant
Rogue_Ant's Avatar
Got them, and sent an email back... You are missing the little daughterboard which goes in-between the chip and the socket.
Old 08-09-2015, 07:17 PM
eman930
eman930's Avatar
Any chance I can buy that board from you
Old 08-10-2015, 07:55 AM
eman930
eman930's Avatar
Is the board the same for the M-tune?
Quick Reply: A-tune help needed
