length/source for kw rear coilover to trailing arm bolt?
I bought a second hand set of KW V3s. Unfortunately they came without hardware. Can someone tell me what bolts I need for the rear lower attachment points?
The factory bolt is no longer available and really hard to find from hardware vendors. Fastenal does not have it for example.
Make doubly sure that the bolt doesn't bottom out on the threads.
Wind it in by hand (without the shock) and make sure the gap between the head of the bolt and the shoulder face on the suspension arm is smaller than the shock spacer length, by at least 2mm.
Otherwise the bolt won't clamp the shock spacer to the arm with sufficient force, the bolt will then be exposed to bending fatigue, and it WILL fail.
Cheers,
Mike
Cheers,
Mike
