Aeroquip fuel line fittings
Old 09-14-2003, 05:38 PM
Pauerman
Pauerman's Avatar
Question Aeroquip fuel line fittings
Does anyone know if Aeroquip makes a metric hose fitting that will bolt onto the stock fuel damper?
If Aeroquip doesn't, is there any fitting company that does?
TIA
Vic
Old 09-14-2003, 07:06 PM
badcoupe
badcoupe's Avatar
Not sure But I don't think so. I use aeroquip on my mustang and I don't recall in their catalog seeing anything metric. If I remember correctly you don't have use the dampner, all you need is the regulator.
Old 09-14-2003, 07:47 PM
tazman
tazman's Avatar
www.batinc.net
You need 16MM.
Old 09-14-2003, 08:04 PM
keith
keith's Avatar
How about the other end??
Old 09-14-2003, 08:11 PM
Pauerman
Pauerman's Avatar
Default Fuel Lines
I am planning on using AN fittings for the hard lines coming through the strut tower - I will flare the ends of the hard lines as necessary.
Old 09-14-2003, 08:15 PM
dand86951
dand86951's Avatar
There are metric size fuel injection grade lines available that you can use along with clamps to replace your stock fuel lines. They don't have the braided outer covering but if you want that the most local speed shops have the dress up kits. You would have to cut off the original hose with a dremel tool, carefully not cutting into the fitting, do the same on the end that mounts to the car, then take the old hose and fittings down to a hydraulic hose shop and get the appropriate size metric i.d. fuel injection grade hose and clamps. You will then have the best hose for the purpose.
Old 09-15-2003, 11:20 PM
Pauerman
Pauerman's Avatar
Default 16MM damper fitting
Tazman - called BAT and inquired about the hose fitting for the fuel damper. They were very helpful and offered a couple of solutions.
1. Use a female/female adapter with metric threads on one end and JIC or standard threads on the other. This way, a standard type adapter can be attached to the damper, and fitting a -8 reuseable hose fitting would be readily available.
OR
2. Use the 16MM x 1.5 reuseable hose fitting that bolts directly to fuel damper. The only problem is that their hose fitting will only accept a -6 size hose.
Did you end up using a -6 hose size for your fuel damper?
Old 09-16-2003, 12:02 AM
tazman
tazman's Avatar
Yes I did option 2 and used all -6 hose. I even replaced the line from the damper to the fuel rail.
Old 09-16-2003, 12:40 AM
Pauerman
Pauerman's Avatar
Thanks Tom,
Would you happen to have the part #'s for hose fittings on the rail to the damper?
I might as well upgrade that hose too now that I'm here.
Old 09-16-2003, 12:55 AM
Sam Lin
Sam Lin's Avatar
If you guys wouldn't mind, I really want to do this for the peace of mind, and a list of all the parts you used would make it a lot easier.
Thanks!
Sam
Old 09-16-2003, 10:30 AM
Jeremy Himsel
Jeremy Himsel's Avatar
Vic,
Sorry I missed your call. I pulled the head and pan off that motor and it looks like brand new so off to the welder it goes....... Anyway, give me a call at work today.
Old 09-16-2003, 12:39 PM
Jon Moeller
Jon Moeller's Avatar
Tom,
I'd also really appreciate a parts list, or a write up, if you can find the time, by any chance. I think that would be an excellent addition to the tech info already on the board.
Thanks.
-J
Old 09-16-2003, 02:48 PM
smokey
smokey's Avatar
Please.
Old 09-16-2003, 04:01 PM
Mike B
Done With Sidepatch
Mike B's Avatar
Ditto Tom...Would make a great winter project...
Old 09-16-2003, 07:12 PM
tazman
tazman's Avatar
I will do it later tonight. I have to go finish cleaning my garage when I am done eating right now.
Quick Reply: Aeroquip fuel line fittings
