Engine harness - wire length needed
I'm building new '88 engine harness, I'm almost done but I'm stuck in place now. I have an old '86 harness as a template/donor and it does not have oil level warning wire. See sketch below - I need length of a sleeve for oil pressure sender and total length of the oil level warning part - from where yellow cover comes out of the main sleeve to the end of the plug. Your help will be much appreciated, I don't want to do it either too long or even worse - too short.
I can measure an 86 harness in the morning for the pressure sender, if that helps. Don't have a spare harness with the level sender. Maybe leave it very long and cut it as needed once installed?
I'm using '86 as a template so I have the total length but thanks a lot anyway for your offer. I can kinda estimate these lengths but I would prefer to have them measured. I don't want to leave these as last and cut to length once installed because I'm using braided sleeve and start dressing harness "legs" from smallest first making my way towards larger diameter and firewall. Leaving these uncovered will force me to leave the whole part without sleeve. I don't know if this makes any sense what I'm writing here, I've never been good in describing things, I prefer to make them...
Tom, you misunderstood me a bit. I start from smallest sleeves and fit them in place (shrink tube with glue) than larger diameter slide over this one, shrink tube in place and so on. I start with smallest and finish with the largest at firewall. I know that the easiest way would be to measure it under my car BUT car is at home and I'm away working now. Lot of time after shift so I figured why not build a new harness? LOL. Anyway, there is no way my wife would get under the car to do it for me... I don't even try to ask her, I think most of the guys understand this.
Anyway, maybe I really overthink the whole thing, I'll just estimate it and eventually redo later.
