Newbie question
Hello everyone
Well I am new to this group but I have been lurking around for more than a year now. I have learn a lot from all of you and have found answers to almost all questions true this group. This is a very good reason of why I did not post in the past, the other is that my English is kind of weak (French from Quebec). But this time I have to take the plunge because i really need help solving my problem.
After a little incident whit my engine I have to take some decisions for my next year track season. Here my question; I blew my head gasket on my 2.8 stroker and found out when I remove the head for the repair that the #1 cylinder wall was badly damage due to a broken ring. Scoring is important and it will require more than .75mm (bore) to refinish the wall properly. Now what should I do?
I want to keep my 3 litres crank and rod but I will need new pistons, rings and all the tralala (seals stud’s gaskets etc.).
What should be my route in this reconstruction project?
How big can I bore or how big should I bore (block is 44/52) 102mm, 103mm ….. What kind of pistons and rings is available, should I think about sleeves and do you think that bore and stroke engine can be reliable especially for the track.
Thank in advance for all your suggestions and advices
Mic
Mic
Rest In Peace Jaak
Cable Guy
Cable Guy
Mic ... give Markus a call. He can guide you. His shop is just outside Kingston, Ontario; a few hours drive from you.
Markus Blaszak
Blaszak Precision Motorsports
4835 Holmes Rd.
Inverary, Ontario
Canada, K0H 1X0
www.BlaszakPrecision.com
613-353-7012
Jaak Lepson
Markus Blaszak
4835 Holmes Rd.
Inverary, Ontario
Canada, K0H 1X0
613-353-7012
Jaak Lepson
