Intake valve pic and question
Going with the pack
is quite monotonous.
#2 and #3 intake valves look like this, #1 and #4 look new.
Are these not sealing properly?
What seems to be the problem? Looks like 2 valves were changed at some point. Some valves look like that new.
Going with the pack
Head has never been off the car.
I had intake off and took a peek, 2 valves look like that, 2 look new. Just making sure it isn't a sign of something I need to take action on.
Brad - If the HG has never been changed I would change it. The gasket deteriorates over time. I would also change the oil housing seals as well if they have not been done. Do you lose any coolant?
Going with the pack
No I'm not losing any coolant but I did just start weeping oil around the cooler/block area after the last track day. I pulled the intake because I broke one of my reference sensors - replacing both as part of my 'replace everything that could cause the car to cut out in 10b' project. I suppose I should add the HG to the list.
Discoloration may be caused by a bit of oil leaking down from the guides. If you pull the head, you could have them checked and also replace the valve seals.
