Oil pressure gauge/indication
Hi guys!
I got a question/problem with the 944 turbo -89; the the oil pressure indication has gone bad after engine wash. When i put ingition on the oil pressure gauge indicates max./above 5 bar. When engine i started, it stays there at max. and never drops. I have driven the car a few times up to 30 min. and still max./over 5 bar-indication.
Where should i begin? Does this mean a faulty oil pressure gauge or faulty electrical/wiring?
Any help is very much appreciated!!
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Like many things on this car, replacing the sender is a PITA!!! Make sure you don't buy a URO, buy the real VDO from Sunset Porsche in Oregon. The best price on a real gauge. 50% of the aftermarket ones don't work and you Don't want to do this again. Get ready for the oil to pour out too when you remove it. It takes a 15/16 or 24 mm wrench. You will need a stubby version if you don't pull the PS lines. I would recommend removing the PS lines. It makes this job much easier. Good luck.
PS: pay close attention to where the wires go, take a picture. They are polarity sensitive, only work one way!
When working underneath with the car on a lift, with a stubby 24mm it should be possible to replace the sender without messing around with anything else, Power steering pump, lines etc.?
