86 944 rear cargo mat
I'm having the same trouble too with mine. Here's the link in case you don't find it: http://www.clarks-garage.com/pdf-manual/body-28.pdf
Sorry, didn't mean to sound offensive in the last post!
Just went through this. Ian has newer caps that you may need to slightly drill and epoxy on the spring side. As you get it apart I found the spring retainer slipped off the rod. Epoxy helped hold it together and the caps fit fine. Was easy to fix with the dremel.
