Need Advice for Glue for Hood Heat Shields
My front hood heat shields are consistently peeling from the hood, does anyone know what I can use to glue them back to the hood
Best Wishes
Best Wishes
3M makes an aerosol adhesive called "Super Trim Adhesive" part #051135-08090. I have used this several times with excellent results. One caution, make sure that your pad is in the right position because once you put the two surfaces in contact, you are not getting them apart again.
