Stoptech ST60 and 355 rotors for 951?
Then they are locating bores.
To keep it simple make sure your adapter interface extends to the flat area and just bolt it down. Otherwise you need to CNC spuds into the adapter itself.
I have a set of 355mm
I had Brembo help design me a few sets of 355mm rotors using the StopTech rotors and billet hats for the 928 S4's + and 88S-89 951's.
Nice stuff: I have one set left: you use these with either stock S4 calipers or BigReds (either would be spaced with longer bolts & spacers). Notch the pads for full annulus coverage. I race on these, had them for a few years now, both street and track. $1400/set for my last pair, x-drilled stop-tech rings as-pictured.
kachunk/xschop, anyone still sourcing these stoptech st-60 adapters? if I had a local machine shop make these is the drawing in xschop's post on 05-19-2015, 08:17 PM are what folks using to make these? On the rotor side, are the 911 355mm rotor ring/hat used off the shelf?
MarkRobinson, on another car planning to do your same setup, 928s4 calipers with stoptech rotors. have adapters to mount the radial calipers to a nonM030 968 but interested in where to source the stoptech rotor rings/hats. was hoping one of the 911 rotor rings/hats will work off the shelf.
