951 331 667 00 Axle stop washer. Where does this go?
I think it is the two thick spacers. I think there is one each side, on one of the four bolts that hold the carrier to the torsion tube. Its a thick (1/4"?) aluminum washer.
Brian's correct.
When you put the aluminum bearing carrier back on the end of the cross tube, one of the lower bolts uses the spacer, and the spring plate rests on the spacer when the suspension is at full droop.
The 951 part number is probably a supercession from a previous number.
