Minimum necessary for cluster to function
I have carefully & with purpose gutted the interior of my 1986 951. I traced all wiring, replaced all old and brittle & neatened up. Replaced most all of cooling system, all fuses.... Should I be able to connect the A-B&C connectore to the back of the cluster & expect it to operate? I only have a red light indicating connection to the battery - nothing else.
Any advice is greatly appreciated.
Nick-Ricky
Nick-Ricky
Might as well reply to myself
There is a red plug in passanger footwell that mates to a red plug which feeds a-b-c plugs in back of cluster
all works as should except the temp gauge, which at key pos 2&3(run) temp gauge is automatically at the top
temp switch & sending units at head appear new, I have re-done the wires on both about 3" back, with protected fem connectors, and a generic square snap clip thing
back to the elec wiring diagrams !!!
Any help is greatly appreciated
Thx
Can you help me better see through the fog re:
The square plug sensor & the spade one - does polarity matter? Square plug to dme I guess looks like it has 2 brown wires
Thx
Thx
http://www.clarks-garage.com/shop-ma...19.htm#coolant
Test the sensor with the spade connectors, as it controls the gauge. The other temp sensor is for the DME and is irrelevant to the cluster, so forget about it.
