Easy Dual Port Wastegate Questions
Three easy questions:
Is there any advantage to stepping up to a dual port wastegate if you don't have either a manual boost controller or an electronic boost controller?
Is there any reason why a device such as Reliaboost-1 controller couldn't serve as a MBC in a dual port WG?
Is there any difference in how Reliaboost functions vs. a manual boost controller?
TIA
TIA
Reliaboost is a MBC, just a different design and supposedly more accurate. I have no personal experience YET. You can use a Reliaboost or MBC on one port with the other port open, depends on the WG as to whitch port to use. Pretty much anything iss better than an aged stock WG.
