Turbo CV joints and Axle Shafts-Are They the Same as NA?
I know they will fit but what exactly are the differences between standard 944 axles and the Turbos? I seem to remember hearing there are different splines on the axle to the CV joint but if replacing the entire axle, is there a difference? Are the turbo shafts and/or joints stronger and more durable?
Most of the time parts suppliers don't make a distinction between the two but sometimes they do so I just wanted to make sure before buying an axle that I might have problems with.
Also, are the CV joint bolts reusable or are they stretch bolts? I seem to remember hearing that they should be replaced but I can't find anywhere online or in the factory service manual which confirms this.
Many thanks
Many thanks
The axles go by offset, or year, not model specific. So if you have an '86 or earlier, there are axles for that. If you've got an '87 or later, there are axles for that. The only set of axles that are model specific are for the 968.
If it were me, I would always change those bolts when putting in new axles. You don't want to strip those bastards.
The splines are different. The later version CV joints have larger ***** and tend to last longer, cope better with track use. They are also lighter -- less material. The CV joint has the same diameter and bolt spacing in both versions and the CV+axle versions can be used on any 944-series model.
25 spline CV joint from an 87 Turbo on the left (951 332 901 00), 33 spline CV joint from an 87 944S on the right (944 331 901 00).
Turbo joint definitely has larger ball bearings. Boots are different too.
Is there any difference between Porsche OE joints and aftermarket GKN Loebro joints? Quality, durability, other?
I have seen stated on rennlist before that there is, but I don't have any first hand experience comparing an OE vs GKN.
Despite my obsession with the difference between OE and OEM, I don't have any data on this.
Cheers,
Mike
The offset doesn't matter with regard to axles. The same axle that fits a 83 also fits a 90.
And as for the bolts, the worry is not that they might strip, but that they might come loose and then cause troubles. I suppose replacing them is simple enough but just could have sworn that i had read how they must be replaced. Then again, maybe not.
Thanks for the other posts with information especially the one which shows different ball sizes. I had never heard that before though not sure if the ball size would actually determine the strength or durability.
Also, not sure if the spline difference is about durability or just an update to a different supplier or design....Did Porsche maintain the bigger ***** for turbos throughout its lifetime or did they mix and match?
Sorry to revive an old thread, but I'm wondering if anyone knows the articulation angle of the 25 spline turbo CV joints? The non turbo I believe is 22 degrees. The axle length and bolt pattern is the same, so both 944 and turbo axles can physically be swapped, but if the articulation isn't enough, the cv's could be destroyed, which I hope to avoid.
Btw, early 944 na axles are not interchangeable with turbo, only the aluminum arm cars can interchange, so from 86 onwards. Late offset 87 on made no change to axle length.
Roger
