FS rouges 80lb
03-18-2015, 11:16 PM
Selling rouges 80lb fuel injectors less then 1k miles doing a 3l build need bigger $300
03-18-2015, 11:57 PM
No idea what they are worth ! Help me out
03-19-2015, 08:44 AM
Quote:
Originally Posted by
JBrown
Unless you're running E85 I thought the 80's were fine ?
03-19-2015, 08:46 AM
blade7
I was told they are only good for 425 wheel am I mistaken ?
03-19-2015, 09:20 AM
AddictRennlist Member
03-19-2015, 09:21 AM
Professional HoonRennlist Member
JBrown
400 wheel hp.
mine maxed out on e85 at 5700 rpm. 18psi.
Edit: on e85
03-19-2015, 10:36 AM
What size do I need for mid 500 wheel on 93 with water meth injection ??
03-19-2015, 10:39 AM
M-tune options are 80 and 160's in the drop down when ordering
JBrown
03-19-2015, 10:44 AM
03-19-2015, 11:36 AM
Ok $300 for the set have under 1k miles !
03-19-2015, 11:37 AM
Ok guys $300 for the set less then 1k miles
03-19-2015, 04:30 PM
Not trying to ruin your sale but you can get a new set for around $200, maybe less.
Amazon has them for $45 each.
I was told they are 100 each new
03-19-2015, 05:37 PM
Those Siemens are dirt cheap new...
Anyway I recommend using Bosch EV 14's as replacements but Rogue/ Lindsey has to modify your code due to low/ high impendence .
