safe reliable modifications
Eyal, boost enhancer= reliaboost, so just buy the chips with no reliaboost, and yes it just tricks the wastegate by not allowing the pressure to get to the wastegate until a pre-determined figure.
No, you don't need to take it off. Just back out the adjuster so that you have stock boost of 11psi. This will work with the stock chips if you have stock boost levels. I offer a discount on our chip-kits if people already have the same components like 3-bar FPR or ReliaBoost.
cool, I will likey be purchasing a kit from you this winter, according to the previous owner, the car is set to stock boost, and i do read the right boost on the bar gauge. Is the reliboost that comes in your kit any better then mine, I don't have the comapany name available to me at the moment. Could be Lindsey racing, I'm not sure. For what it's worth, its color coted, i think I'v seen some that aren't. also, Danno, can you help me install the chips tune the car up nicely for me? is that possible? I would be able to drive up to santa barbara. thanks.
