ignition coil
Would you ever replace a working ignition coil? Can it "wear" (probably not the right word) so that it affects performance but still works reliably?
I am chasing a problem where my car feels a bit sluggish, both on and off boost. It feels ok at very low throttle, but once I open it up a little more, the response is just a bit weaker that I expect. It's intermittent, but when the problem is there, it's at both part throttle and WOT. I am running out of things to test. From all the troubleshooting I've done, I'm leaning away from it being a boost or fuel issue. Among eleventy million other things, I have replaced the distributor cap/rotor, plugs, and the plug leads are about 2 1/2 years old. But I've never touched the coil.
Most info I've found suggests that they either work or don't, and if the car runs you don't bother with the coil. But some people claim to have experienced an improvement in an already running car. If I could fix my problem for the price of a new coil I'd be ecstatic...on the other hand, it might be a complete waste.
Freedom Enthusiast
When my coil went out, the car started shutting off or failing to start very erratically. I didn't really notice a drop in performance.
Coils can crack, and then usually they will "leak" spark, across carbon trails. Spray it with water from a mister to see if there is a tattletale misfire and light show. In fact, do this with all your ignition leads... In the dark.
Check to see if there is proper resistance between the two circuits. I think Clarke garage has the procedure. Coils don't seem to fail as often as people replace them.
Intermittent sluggishness would not make me think coil, but I suppose it's possible. Can you just borrow one to see if that works?
Intermittent sluggishness that would make me think more about bad connections somewhere, especially if the issue is all or nothing -- i.e., it either runs perfectly normal or it runs sluggish, with nothing in between -- is that what you have? A friend, for example, had cracked colder joints in the KLR which was causing the car to switch over to the WOT maps from time to time, but otherwise ran fine. Very difficult to track down since everything checked out. Maybe give the harness, dme/klr solder joints, and all the electromechanical stuff (TPS, AFM, etc) a good once over to see if they are failing) -- to the extent you haven't?
I have driven with a voltmeter hooked up to the WOT signal and it seemed to be working correctly but the KLR could still be causing other issues. I thought it might be pulling ignition timing due to a fault.
As regards it being all or nothing...it's very difficult to say, but I think it can vary by degrees. Sometimes I'll be convinced there's a small difference...and then it will stay the same for so long I'll become convinced I just just imagined it. Then out of nowhere it will change. I won't lie, it has made me question my own judgement often!
Sorry about that -- been there and know how frustrating it can be. You might also check the knock sensor and it's connector -- it can cause screwy behavior too...
Replaced...the old one and it's harness looked so bad I was convinced I'd found the problem. But replacing them both (along with the fuel injector harness) didn't help.
Just throwing darts, but I once had a bypass valve that would stick open occasionally, which seemed to perfectly imitate an intermittent electrical issue...
I yanked the DME and KLR to take a quick peek at the boards. I did find some strange looking discoloration. I wonder if it could be water damage, because I did have a leaking battery tray before.
Here's the KLR - these yellowish marks are all over the board:
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/653x490/20150301_134507_3e4f3e3c791eb776ac228901bc7dfc4fe11b88f7.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/653x490/20150301_135031_0a3395647f109a6cb59fb54cadd1c08fb4860bd4.jpg)
And here's a few things that looked odd in the DME. First, the half of the solder joints on the big ribbon cable had what looks like burned flux on them. I have seen this before on circuit boards but never really knew if it's bad or not:
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/653x490/20150301_135749_6b5f576b263cdfc0cd7e2ae199de628e1ede5fb4.jpg)
And this looked really weird to me - what is this stuff is on the big transistor (coil driver?)? It looks similar to the stuff in the previous pic, but I've never seen it quite like this before:
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/653x490/20150301_140818_a2e96aaa70836a2ac281c4ad666c32eed502e0dc.jpg)
