951 Suspension Upgrades
I just wanted to know what suspension setup is possible without spending insane money. I'm looking to lower the car so there is no gap between the tires and the fenders in front AND back. This is with 17 inch wheels. I also want the ride to be pretty stiff so it could handle better. I plan on upgrading the sway bars also. Thanks guys.
Silverbullet,
as i understand it, having your suspension too stiff can be detrimental to traction unless your on a smooth track, eg look at the hammering that the new nissan 350Z track got for its poor handling attributed to overly stiff suspension.
just another angle to consider I guess.
Front coilover conversion from Paragon: $250
Rear torsion bars from Paragon: $266
968 M030 30mm front and 19 mm adjustable rear sway bars from Sunset Porsche: $400
I have the M030 sway bars and am planning on going with 300 lb springs and 29-30 mm torsion bars this winter. From everyone I've talked to this seems to be the best street/track compromise. As long as your willing to do the wrenching yourself, the cost isn't too bad.
What Skip said, altho I would add the M030 caster blocks for the rear of the control arms. I would seriously consider skipping the rear torsion bars and just spend the time to reindex the ones are your car, and limit the front springs to no more than 250#, unless you are an all-out track junkie and can REALLY (and be honest with yourself on this one, okay) drive your car. Lastly, I would get Pagid Orange brake pads, the 5/33 proportioning valve and ATE Super Blue brake fluid and keep it flushed regularly. This will give you a VERY neutral handling car that will outhandle almost anything else out there (short of all out track cars) that is still very comfortable on the street.
One other thing... stick with the factory rubber bushings. They are designed to properly load the suspension. Going to delrin generally leads to early suspension failure and really doesn't do a lot for making the car handle much better, imo.
Regards,
Regards,
What do you consider expensive ? We carry Koni sports which are very popular replacement at 150$ each for the front,and allow you to adjust the firmness,combined with Weltmeister 250lbs springs.
I personally run racing shocks and struts from Bilstein in front and back combines with Weltmeister 250 up front, and I see a good difference between this set up and the Koni set up with the same spring. The car is at the perfect hight for track events(legal), there is less squatting under hard acceleration and less leaning in corners (more neutral and much stiffer).This set up will cost a bit more,but you get shocks that are tuned for rebound and compression,and you get full front struts.1600$ plus the springs about 250$.
Oops, I forgot about shocks. I went the way of the Koni adjustables from Paragon and have been pleased with them. Paragon has them for $154 ea. for the fronts and $116 ea. for the rear. I also agree with sh944 regarding the 968 caster block - Sunset Porsche again for these.
One thing to keep in mind with spring rates is that everyone's tolerance for stiffness of ride is pretty different. So while I have a friend that runs 450 lbs springs that they feel are just fine for the street, there are others who feel 220-250 lb is the highest to go. The other issue that sh944 pointed out is that it really depends on what you are going to use the car for. I am definitely setting my car up with an emphasis on track use and I am more than willing to compromise street comfort, but to each his own.
Hey, thanks for the replies.
Well for the setup, I want as little squatting as possible and I want as little leaning into corners as possible. I know that setting up the suspension too hard will harm the handling characteristics, but I'd be willing to compromise street comfort for great handling. If there are any track events, i'll have a nice setup.
I consider almost 2000 dollars for just front struts and springs expensive.
So what springs should I get? 250 or can I go higher? I might as well go for the koni adjustables and i'll upgrade the sway bars. I already have pagid blacks and ATE super blue brake fluid. I'm going to install the pads soon.
What will the M030 caster blocks do exactly?
Now about lowering, if I get the koni adjustables, how do I adjust the height for the rear? I have a set of KYB's on it now and I don't thik there is any way to adjust them. Thanks again.
For the front suspension, Koni sells a kit that converts your stock struts to Koni sport specs (the internals are replaced by Koni components to modify the dampening). They also have coil-over like kit that is height adjustable.
Check out Paragon under "suspension" for the 944. They will even do all the work for you if you can have some down time. This should cost well under $2k.
So what springs should I get? 250 or can I go higher? I might as well go for the koni adjustable and i'll upgrade the sway bars.
Now about lowering, if I get the koni adjustables, how do I adjust the height for the rear? I have a set of KYB's on it now and I don't think there is any way to adjust them. Thanks again.
My advice is to call Jason at Paragon Products. You will not find a nicer guy at a better company. Search the list and you will find that they are by far everyones favorite vendor. Also suspension componentry is one of their specialties and they will be more than willing to talk to you regarding your setup and make an appropriate recommendation.
Originally posted by streckfu's951
Actually, the rear can be lowered by about an inch without having to access the torsion bars.
I would take a close look at the Leda front coil overs and rear coilovers. With 300# up front and about 100# helper springs in the rear, then lower the rear either via reindexing or just adjusting the trailing link, then add the M030 sway bars. You would be a bit over $2000 but it makes a very good combination street and or track set up. Talk to Karl Poetl at Racers Edge, he can supply the parts and has lots of track experience with the cars. For the track our cars like a really stiff front spring rate and the top cars probably run in the 500 to 600# range. Way too stiff for the street but 300# seems to be a good compromise.
