Some Aussie oil test results
I remember seeing this test years ago at the Buchanan's workshop. Interesting nonetheless Hally. I'd say there might have been some improvements since then. That was at Mobil's low point.
VR1 would give similar results.
On the topic of oil - since the turbo is using the same oil as the engine, has anyone ever considered separating the oil circuit used for the turbo versus the engine? I can't believe that the optimal engine oil could also at the same time be the optimum turbo oil. And as an engine ages and begins circulating little bits of metal, that must be terrible for the turbo.
The cost of a typical turbo probably doesn't justify the expense of separating the oil feeds, but if you were to buy something like a Borg-Warner EFR turbo, that's something that should be considered.
I read on another thread that Evergreen said it's fairly common for the seals on their newly-rebuilt turbos to be destroyed by a new engine in its break-in period due to the amount of metal that gets circulated in the break-in period. A band-aid is to add a separate filter in the oil feed, but what if you completely isolated the turbo with its own cooler (such as the stock oil cooler), reservoir, and an electric pump? It couldn't be that much more complicated, and would be much less risky, and would allow you to run a much thinner oil (think faster spool) than the 20W-50 we routinely hear recommended for the engine. Has anyone done this? Have you ever seen a turbo manufacturer specify the minimum oil weight that should be used? I only found one FAQ that stated the minimum viscosity is SAE 30, but I think that's too generic to assume it's valid for all turbos.
Pre turbo oil filter looks like a good alternative..
https://www.rtmracing.com/xcart/prod...roductid=17923
I will use efr 7064 for my build and will need to think of something on this front.
