Finished the wrap
Love the way it's turning out Devon but am a little worried about the wiring going to your battery. It looks like you have a wire going over the rubber seal and even worse one going underneath. This is really dangerous for obvious reasons. Drill a hole next to the other hole at the left of your build plate, put a grommit in it and then feed the wires through there. Hate to see your project come to any grief because of something so easily avoided
Love the way it's turning out Devon but am a little worried about the wiring going to your battery. It looks like you have a wire going over the rubber seal and even worse one going underneath. This is really dangerous for obvious reasons. Drill a hole next to the other hole at the left of your build plate, put a grommit in it and then feed the wires through there. Hate to see your project come to any grief because of something so easily avoided ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
stills and lower wing was easy as in damages in the paint since she's an old car I did do some sanding on the body . If I didn't do that you will see some of the imperfections. But with some sanding turned out very very good
