Does anyone have Chris White's 60-2 trigger set up instructions
I am trying to help my friend. Cant seem to find anything
So my friend adjusted the alternator belt and moved the location of the mount. Now the car doesn't start. If if i remember correctly there is a little hole like 11teeth before the ground down teeth. so you have to align the sensor to that mark when the engine is at TDC. I don't remember if am 100% correct on this.
This procedure of having a fixed angle before tdc as stated in the installation instructions only applies to the electromotive that Chris is selling. The instructions where from the electromotive manual. I use a different standalone and have 58 deg before tdc or something similar. If he only moved the mount and did not touch the wheel I would check if the center of the sensor aligned with the center of the wheel and that the gapping is correct. If you open up the software you should be able to see if a trigger signal is received.
